can Autotap check for cylinder compression?
Old Aug 1, 2003 | 07:45 PM
WicketMike's Avatar
Default can Autotap check for cylinder compression?
I might have a cylinder that is low on compression, is there a way to check this with autotap
thanks
Old Aug 1, 2003 | 08:49 PM
minivette's Avatar
Default Re: can Autotap check for cylinder compression?
You need a compression tester. Here's a go by, it's in metric but will give you the basics.
http://www.holdenls1.com/index48.html
wrencher's Avatar
wrencher
The best way is the old fasioned compression gauge.
The PCM can see a missfire & that can be retrieved from the data stream.
But the cause of the missfire it does'nt know, you have to check it the same ways.
