lt-1 Edit trans programming
Old Apr 26, 2008 | 08:04 AM
SQ1110's Avatar
Default lt-1 Edit trans programming
Does anyone know how to stop a 4l60e from going into limp mode with a high stall converter using lt-1 edit? The car is hitting what they call "Stall wall" because the computer is picking the stall as a slippage problem and throwing the trans into limp mode and it wont shift out of first unless you lift.I was told I can fix this with my LT-1 edit ,I'm just not sure how.Any help would be greatly appreciated,Thanks, Shaun
Old Apr 26, 2008 | 11:26 AM
2xLS1's Avatar
In Tunercat it is labled VSS Diagnostic Enable Minimum RPM. Should be something similar in LT1Edit. The stock value should be around 3000 RPM. Raise that value to at least the stall speed of your converter or higher until the problem goes away.
Old Apr 26, 2008 | 03:37 PM
SQ1110's Avatar
I'm going to check into that-appreciate it,Shaun
Old Apr 27, 2008 | 11:07 AM
lt170chevelle's Avatar
what happens in limp mode?
Old Apr 27, 2008 | 11:09 AM
oh crap nevermind, i didnt read it all...but curious, what size and brand converter do you have? i have a yank 3400 and havent had any issues except a lockup gremlin every once and a while.
Old Apr 29, 2008 | 08:46 PM
SQ1110's Avatar
It's an ATI 10 inch with lockup. I don't exactly know the Stahl but it's pretty loose. It works tremendously when the car will shift,but i haven't been able to make a real pass with it because of this.Other than that the converter works great.
