LS7 throwing codes ??
Old Apr 26, 2008 | 02:31 PM
bada's Avatar
Default LS7 throwing codes ??
Well I got the LS7 running. But the trouble light keeps coming on. The scanner says misfires.Could it be the motor mounts affecting the knock sensors. They are solid, with no rubber.
Old Apr 27, 2008 | 10:07 AM
bada's Avatar
No one? What will cause the misfire codes. The engine trouble light comes on but the motor runs fine. Like I said could the mounts being solid set off this code???
Old May 5, 2008 | 08:33 PM
bada's Avatar
The code is PO300 misfire. What could cause that? I thought it could be the solid motor mounts. What do you guys think???? HELP PLEASE.
