Knock Sensor Deletion!?!
Old Apr 28, 2008 | 03:47 PM
MR.G's Avatar
Default Knock Sensor Deletion!?!
Can it be done?
I know the car is running perfect at this point with no knock.(performance shop tested)
It looks as though its just a bad KS and/or wire and it keeps throwing the code C0327.
I really do not want to tear intake apart to fix plus spend the $200.00 to get parts if it can wait till late fall.
Will this hurt the car any?I will fix down the road.
Old Apr 28, 2008 | 04:30 PM
ZL1Killa's Avatar
you can delete them with HPtuners or efi live, i don't recommend it but you can. just don't forget about them
Old Apr 28, 2008 | 04:42 PM
Frost's Avatar
as mentioned; you need tuning software.
for the meantime, everytime you go WOT you will lose the max amount of timing allowed (-4deg for F-bodies in PE)
