PCM stops working... works when re-connected
thanks ,Andrew
The car has gotten worse, as the fuel pumps are loosing voltage while driving and the car has to be throttled over 1k rpm to keep the car from stalling.
I plan to replace the PCM but I want to know what would cause this, is it a problem inside the PCM caused by a bad board part, or is it because a wiring issue in the car fried the PCM. This is what I need to know before putting another PCM in the car.
I have read that long term water damage inside the PCM could cause this code. I dont have the tools to take the PCM case off so I can't check.
