Need some help installing LC1 on obd1 LT1
A/C pressure sensor:
Second Question: I am completely lost on how to calibrate this thing. The quick start guide says "connect an indication LED and momentary pushbutton between the black calibration wire and ground." ....ok there are four wires for those for things, am i basically tapping ALL four of those into one wire? that doesnt make any sense to me. and what is the button for?
Question Three: I plan on replacing one of my narrowband 02 sensors with the wideband, and forwarding the narrowband signal from the controller to the PCM. I currently have a narrowband A/F gauge hooked up to this signal wire. My question is, could i relocate this to the wideband output wire and turn my narrowband into a wideband readout? What voltage range does the narrowband output read? Im assuming the wideband outputs 0-5v since thats what the A/C pressure sensor reads, but im not sure if thats something i need to calibrate or not.
Question Four: Stupid question, but is in the console by the shifter a good central location to put the controller?
Thanks for the help
