C5 turbo.Tunning problems.
Old May 11, 2008 | 07:25 PM
396375's Avatar
Default C5 turbo.Tunning problems.
I have a 2000 C5 auto with a single turbo 88K miles.Pump,hot wire and 60# injectors.I just got it up and running with a base tune.The car is fast and I'm happy with the power at 11#s with no knock.My first problem is that when you hit it from a roll and the car down shifts it goes like h*ll and then goes into reduced power mode.If you lean into the car from a dead stop and the car goes through the gears with out down shiffting,everything is fine.Something about the down shifts or the breaking loose of the tires puts it into the reduced power mode.I have to pull over and clear all the codes and everything is back to normal.Most of the codes are history H and only currnet C code is the tilt steering.The car also runs hot at 220 most of the time with a modfied thermostat and fan programmed to come on at 185.That's another problem I need to address after I figure out the tunning.
The other tunning issue is that I cannot load the car up on the foot brake.As soon as you give it any throttle the car starts to shudder and the rpms will not go up past 1400.Almost feels like it something to do with the ABS brakes or the the traction control which I do have switched off.
Thanks in advance.
Old May 12, 2008 | 09:33 AM
edcmat-l1's Avatar
Are you doing the tuning? What are you using? Can you post or email me a log and the tune? I use both efilive and hpt.
Old May 12, 2008 | 03:12 PM
hellbents10's Avatar
LS1Tech Sponsor
1514?
Old May 12, 2008 | 04:23 PM
edcmat-l1's Avatar
Originally Posted by hellbents10
1514?
Most likely.........
