Please any help or advice would be great
Ok the past few weeks i have had a po200 code show up and make the car run like ****. I checked triple checked and then when ahead and checked again everything i could from injectors to the antenna being loose ( yeah i did)! This all happen after a jump start that sparked the negetive side........ meaning when i pulled the cables off i hit the ground side. Anyway the po200 code went away ran ok for awhile now it go horrible my lifts where reading - 15 so i upped the injector slope with predetor and that didnt help . Then a new code appeared . po137 code and the car is running like dog **** ... crusing the lifts read - 14 so once again i upped the the injector slope to 14% more still running horrible and know when i start it it idles at like 300 until i give it gas . I am so lost is the pcm fried or what the hell do i do . 2002 chevy camaro ls6 stg 2.5 heads tourqer v3 camshaft headers undrive pully fast 92 intake and throttle body. slp lid slp maf fast 37 lbs injectors . and about a 1000 dollars in asprin .
**** guys i dont even know where to start to find this issue i have read and read .
