predator info
Old Aug 7, 2003 | 10:10 PM
Kansas 99z28's Avatar
Default predator info
made a few runs with the predator tonight, and I wanted to see if my settings were ok. My 02s were at 850-870mv. My spark was at 26.4 at wot, kr was at 0 the whole time. Tell me what you guys think...
Old Aug 7, 2003 | 10:19 PM
Drew778's Avatar
Default Re: predator info
26.?* is what I was running, but I've been told you want the spark at or right around 30*.
Try adding a little spark at a time and see if you can closer.
BTW, the closes I got is 29.?*
Good Luck.
Old Aug 7, 2003 | 11:15 PM
CAT3's Avatar
Restricted User
Might want to add a little PE also, richen it up just an irish hair.
Old Aug 11, 2003 | 02:25 AM
If I dont have any KR shouldn't it be ok. I will add some PE though.
Old Aug 11, 2003 | 02:33 AM
CAT3's Avatar
Restricted User
Yes, it will be ok, i like ot run on the safer side. After using a wideband and dyno, there is so little power lost from 12.5 to 13.1:1 AFR, its funny, depending on your base power, maybe 2hp. But the piece of mind knowing your god, priceless.
