Type of Shift light
Old May 22, 2008 | 04:24 PM
ping2day's Avatar
Default Type of Shift light
Do i have to order any special type of shift light to work with our 2000 ls1 cars. A friend of mine gave me his summit adjustable shift light G2945 to use. I can get the light to come on when i turn on the ignition but when i start the car it will not come on with rpm. Do i have to clip any wires on it for it to work. Summit told me i needed some sort of box to make it work. Is this true?
Old May 22, 2008 | 09:36 PM
ping2day's Avatar
Does anyone know the answer to this question? I want to try and get it working for tomorrow nights race.
Old May 23, 2008 | 11:51 AM
Goldfinger911's Avatar
My Autometer Pro Shiftlight works fine. You need to set it up for a 4cyl car because of how our coils fire, however.
Old May 25, 2008 | 10:40 AM
ping2day's Avatar
Ok thanks i did try that with the summit light, but it did not work. I will have to get a Raptor or something similar i think.
Old May 26, 2008 | 11:03 PM
JonCR96Z's Avatar
Do you have it connected to the right wire? It should work in 4cyl mode.
Old May 27, 2008 | 09:53 AM
Randy WS6's Avatar
I use the Harlan shift light on my 2000 WS6, very nice and compact, and easy to install
Old May 27, 2008 | 02:06 PM
ping2day's Avatar
Yes i have it tapped into the white wire on the bottom block. Posts say pin 10 for 2000 camaro white wire. I will look into a Harlan or Rapture light. I think the digitals are supposed to be plug and play with our cars.
