? about wideband commander
well in the install instructions they show the sensor connections in the module thingy. the order is orange, blue, green,yellow,w/b and red. when opened it the order was o,g,y,b,w/b and then red. i swapped the wires to what the install guide said could that be my problem? or could it be an internal module problem?
The grounds will cause the non-connect issue and also the wb02 issue. I do not think it matters if the sensor ground and the heater ground are the same point, unlike other meters that have ground offset issues.
This is a great wb02, packed with features and reliability.
edit: i just checked continuity from my grounds to my battery and from the power wire going to the module and my B+ and its good theres continuity. my o2 sensor still doesnt warm up either. is there anyway to check for a failed wideband module?
The wideband commander is loaded with features. If you plan on spraying it cant be beat for safety.
