timing ???
Old Aug 10, 2003 | 04:54 PM
blue98coupe's Avatar
Default timing ???
what degrees should I set timing for cruising and wot ??
Old Aug 11, 2003 | 02:18 AM
Cal's Avatar
Cal
Default Re: timing ???
Cruising = 40*, WOT=30*. If you get a bunch of knock retard then back it off some.
Old Aug 11, 2003 | 11:17 AM
ok next ? what tables do I use to adjust these
Old Aug 11, 2003 | 11:31 AM
Cal's Avatar
Cal
Do some data logging with EFILive first, you shouldn't need to adjust them unless you have done major engine modifications. You will see the High Octane and Low Octane Spark Advance tables under the Ignition tab of Edit Engine Cal.
Old Aug 11, 2003 | 01:59 PM
ssdungeon's Avatar
Thanks Cal I was looking to hear just that. I have my timing at 29.5 no KR and may be able to get 30 I stopped adding timing b/c of while cruising I saw a long list of 38 and a good bit of 42. Now that I know thats normal for cruising I wont worry so much.
One question though Is it normal for every now and then on a drive for my timing to drop to 24-26 at WOT. say in 5th gear doing about 65 mph. Usually its 28-29.5.
I used the High Octane tables.
Old Aug 11, 2003 | 03:47 PM
Cal's Avatar
Cal
I would say yes; that could be caused by bogging it just a tiny bit as you make the gear change at a lower than normal rpm with more throttle opening than usual. The PCM trys to adapt to your driving style and advance the timing all it can, but it might have to pull some timing if you lug it more than you normally do.
