How do I improve initial throttle response
Old Jun 1, 2008 | 09:36 AM
LS1-450's Avatar
Default How do I improve initial throttle response
Have played around w/ VE & spark, but am not getting the response from just opening to say 3% TPS change. Usually, it takes more opening before the RPM's come up. What is the proper adjustment to get the response earlier? Thanks (EFI Live tuning software is used)
Old Jun 1, 2008 | 10:46 AM
edcmat-l1's Avatar
3% change on the scanner, and it doesnt do anything? Or does it just "feel" like you're giving it about 3%?
I would make sure your scanner is seeing the slight change in tps. And if so, thats a bit strange that it doesnt do anything.
Got a log or something? How bout a tune? Could be something to see there. I got an idea but will reserve comment for the time being.
Old Jun 1, 2008 | 11:03 AM
LS1-450's Avatar
It feels like 3%. This morning, I made a throttle follower & paramater change. Plan to make a new log today. Here is the tune before today's follower change. Have also added the dump file from the previous log. (dump file was before the posted tune; spark & VE mod's. since then).
Old Jun 1, 2008 | 01:44 PM
LS1-450's Avatar
edcmat-l1,
Here is today's log file. The throttle follower & parameter changes seemed to have helped. Chages were:
-TPS % change is now 0.29% (parameter)
-Airflow g/s change is now 0.00,0.05 0.50,0.11 1.00,0.11 1.50,0.22 2.00,0.22 3.00,0.54
all others were left as they were (throttle follower). Should I continue w/ an airflow g/s increase or are there better solutions.
I am a complete newb @ tuning & have just begun changing the program. The knock retard @ WOT needs some more work, as you will see. any other suggestions are appreciated. Thank-you
File Type: efi
