How do i Set up PID's to measure RAF?
Old Jun 1, 2008 | 10:27 PM
CAMAROZ28AQUINO's Avatar
Default How do i Set up PID's to measure RAF?
Hey guys, im using HPtuners trying to log Base Running Airflow in Gear and in PN. How do i set it up so that it will work? I have a couple .cfg's already that "are" set up to log this but when i go into the histograms it says "This histogram is not supported with the current loaded parameters." What do i do to get it to work so i can dial in my idle?
Old Jun 2, 2008 | 08:19 PM
bump for some LS1tech help
Old Jun 2, 2008 | 08:56 PM
foff667's Avatar
LS1TECH Sponsor
There should be some histos & PID info on our forum http://www.hptuners.com/forum/ the pids themselves in that some people like to simply plot their STIT's while others use STIT+LTIT and plot that, to create the histogram you just need to go into the configure histograms window, choose an open histogram & select the PID you want to plot ie STIT then for the axis simply choose the idle airflow table & it will attempt to plot it against that so long as you are logging the necessary parameters. There should be some histo's premade in our histogram repository though.
Old Jun 3, 2008 | 06:04 PM
Viper's Avatar
Use this one
File Type: zip
Idle-Airflow.zip (974 Bytes, 68 views)
