Bosch 13111 o2 sensor problems
I have a 98 m6, LT's, ORY and I am having o2 problems. I just replaced the two fronts with the 13111 and now it seems that they are giving me lean codes on (sensor 1 bank 1) (Sensor 1 bank 2) (sensor 2 bank 1) (sensor 2 bank 2) are these new o2's bad or what?
Guy at Autozone told me that I need some spark plug foulers to move the o2 sensor so that it would read correctly is this correct?
Guy at Autozone told me that I need some spark plug foulers to move the o2 sensor so that it would read correctly is this correct? Last edited by Swaie; Jun 2, 2008 at 09:36 PM. Reason: info
For you it would be hit or miss, it wouldn't be worth the effort, and I've never heard of it being done with an LS1.
Why did you change them?
Thats done toyotas, you do that on the rear o2 when you remove the cat and the ecm never knows it's gone when you move the sensor away from the heat.
It's hard to believe that 4 sensors are bad rather than believing that one or more are working right, and the car is really lean. Check your fuel pressure at the rail. If it's good, find someone with a scanner who knows what they are looking at to see what the MAF is reporting, or maybe see if you can borrow a friends MAF and see if the codes go away and stay.
