E85 383 LT1 tuning
383 with flat top pistons and 5.7 rods
around 9:4:1 DCR
cam specs 230/236 .544/.555 with 1.6 rrs
ported heads and intake
52mm TB
37 lb injectors
255 lph fuel pump
any help is greatly appreciated as i would really like to convert over
Basically, E85 requires a different air to fuel ratio - all else being equal, it needs to be richer then with unleaded gasoline. Because of this, injectors that are borderline too small for a gasoline setup will almost certainly be too small for E85.
I don't see any reason why the LT1 PCM cannot support E85 from a tuning perspective.
LT1 PCMs have PLENTY of adjustment for E85.
My guess is that a 383 LT1 with that size cam would need a larger injectors than 37lbs. If you search around there is a calculator that you can plug some numbers into that will tell you what size injectors you'll need.
