WOT and CL
Old Jun 6, 2008 | 06:18 AM
minytrker's Avatar
Default WOT and CL
I have a 98 Z28 with all bolt ons, cam, ported tb, and 3600 stall. At WOT the cars stays in CL, so it wont access wot shift points or go into PE mode. I checked the TPS, it reads 0% at idle and 100% at wot. I checked the voltage and it was in limits from the gm service manual. I desided to try a tps relearn anyways and now the check engine light is on for low tps voltage and the car doesnt want to idle right.
Old Jun 6, 2008 | 08:09 AM
JoeyGC5's Avatar
Was the throttle blade giving a true 100% open and closed position. If the relearn has made evrything screwy it'sprobably just a bad TPS or connection. IMO
Old Jun 6, 2008 | 10:43 AM
minytrker's Avatar
I will check it tonight. I did move it by hand to check the tps but never checked the blade.
Old Jun 7, 2008 | 08:30 PM
firefighter813x's Avatar
anyone?
