need help
Old Jun 10, 2008 | 02:41 PM
SheaMus's Avatar
Default need help
i dunno if this is the right section but i just went to get my emissions done...No Dtc's....i didnt pass because the System Readiness test [EPA] was not ready....I hooked up efi live....i had no dtcs but i clicked the clear code...cleared....then drove the car around for 2 hours...still the same problem...anyone know if its a bad pcm?? or something else?
Old Jun 10, 2008 | 03:56 PM
2001NBMZ28's Avatar
There are a couple different readiness tests - EVAP, etc. Only thing I can think of is do a few drive cycles - www.obdii.com/drivecycle.html or see if you can set them complete with your software.
Old Jun 10, 2008 | 04:07 PM
SheaMus's Avatar
thank you...i never had this happen with emiisions before
