o2 sensor issue, p0132, p0134
Full story (cliff notes below):
Friday, the engine started misfiring and breaking up really bad. I took the car into TTPerformance in NJ. Matt Sorian took me right in. He pulled the OE spark plugs which were in bad shape (non-uniform gapping and dull tips). He replaced with NGKs gapped to .500 (I believe).
Car was still not healthy, so he checked the o2 sensors, and both front o2 sensors were reading negative numbers (-18, -100). So he replaced both o2 sensors with OEs.
Car is running healthy. He does partial throttle and WOT tuning on the dyno, car makes good power, and I am ready to go. 5 minutes from the shop, flashing CEL, rough idle, I bring the car back. He road tests the car, driver side o2 is not responding. He leaves the car open loop, and I take the car home hoping to find a solution.
Cliff notes:
05 with 30k, under factory warranty, installed kooks headers, kooks o2 extenders, and corsa catback.
new plugs, new acdelco o2 sensors.
I am having an issue with the front, driver side o2 sensor. The 2 codes are P0132 and P0134 (high voltage; not responding)
Car is currently running open loop so it is driveable.
According to the diablo, the front, driver side (1,1) o2 sensor is reading 450mv while the other 3 are fluctuating within range. I unplugged the driver side front o2 (1,1) and it is still reading 450mv.
I assume that since the ECU is still reading 450mv with the o2 unplugged, the issue is between the ECU and the harness, yes/no? Supposedly, they tested the resistence in the o2 and the kooks extenders and all was well. Bad ground somewhere? What to do next?
I really appreciate the guidance, it's been a tough week.
check your wires at the malfunctioning o2,, check the heater circuit power and ground and check the signal wire and ground
it is probly a ground issue
not all o2 sensors are equal,, my brother had some ls1 o2 sensors(cheapo's), they plugged into the connector fine but would not read on a scan tool, stuck at 450mv
turns out that some o2 manufactures do not ground the o2 sensor housing to the o2 harness ground wire internally(the pcm needs to be grounded at the o2 sensor, actually through the sensor to read correctly), we jumped a ground wire to the o2 ground at the harness and they worked fine
I am pretty sure the shop used ACDelco o2 sensors, would you recommend bosch sensors instead?
i have personally seen several cheaper brand o2's that do not ground the o2 low signal wire internally to the case/housing and it will cause the o2's to not read and the computer sits at around 450mv
