Speedometer problems 2002 trans am
Old Jun 15, 2008 | 07:27 PM
msheffield's Avatar
Thumbs up Speedometer problems 2002 trans am
I have a 2002 trans am with an LS1 and 6-speed, my speedometer recently stopped working as well as my odometer, and sometimes it is hard to shift into reverse. Please help!!
Old Jun 15, 2008 | 08:57 PM
Dex's Avatar
Dex
Well the odometer wont work if the speedo doesnt work. Does the rest of the guages work?
Old Jun 15, 2008 | 09:04 PM
msheffield's Avatar
Default speedometer
Yeah the rest of the guages are working. I already changed out the speed sensor on the transmission.
Old Jun 16, 2008 | 02:32 PM
SouthStreet's Avatar
If your reverse lockout does not work then more than likely the pcm is not recieving pulses from the vss. Hook up a scanner and see if your pcm registers mph. If not, you may have a wiring issue between the VSS and pcm or the pcm and dash.
