Non LSx KR problem
Old Jun 16, 2008 | 11:11 AM
RZRSEDGE's Avatar
Default Non LSx KR problem
My Dad's Impala has been getting crap for MPG. Do a scan and it seems to be running pretty lean at spots and getting KR. WOT instead of the NB voltage jumping up and holding steady; it falls to 40-50 mv range. When this happens as much as 10* of timing is being pulled. Then it will jump up to 700+ mv for a thought and KR eases off, and then same thing, reading falls and KR comes back. Any help is greatly appreciated. 3.4 V6 by the way.
Old Jun 16, 2008 | 11:26 AM
Rhedalert's Avatar
it's either a fuel or O2 sensor problem, more likely the latter. How many miles on the car?
Old Jun 17, 2008 | 10:04 AM
RZRSEDGE's Avatar
The o2 was my guess also. Don't have to throw a code to be bad? Mileage is over 100k so it's time for things to go bad.
Old Jun 17, 2008 | 02:38 PM
Rhedalert's Avatar
I swapped a 3.4 Impala motor into my '95 Olds, along with the PCM and harness. I have modified the program with a tuner, and have scanned it extensively. The O2 sensor voltage always holds steady for me at WOT, never had a dip even during shifts. Given the mileage, I would replace the O2 anyway (it usually won't throw a code unless it's WAY off, and acting up during part throttle driving too).
Old Jun 18, 2008 | 07:52 AM
RZRSEDGE's Avatar
Will do, thanks!
Old Jun 18, 2008 | 10:15 AM
wait4me's Avatar
Id look at fuel pressure durring the run, It sounds like a crapped out fuel filter or main pump going bad. The lean condition is making it get to hot in the cly and makeing it knock.
Old Jun 18, 2008 | 10:26 AM
RZRSEDGE's Avatar
Thank you. Will also do this.
