weird list of codes
Old Jun 17, 2008 | 06:42 PM
Skyfire's Avatar
Default weird list of codes - log attached
Any idea of what this means?
Edit: also has engine misfire dtc.
Old Jun 17, 2008 | 08:00 PM
Skyfire's Avatar
also, both of my long term fuel trims are as high as they go and my o2 sensors aren't working some of the time. Could this all be related to the o2 sensors or what else might it be?
Old Jun 18, 2008 | 05:15 PM
wad02z28's Avatar
First off any U codes are very common with any reprogrammed pcm's and will eventually go away after a certain amount of restart cycles. So don't worry about them. For the other code are you still running an egr setup or did you delete it. If deleted simply set this code to no error reported. Also as far as the fuel trims go make sure you don't have any kind of a vacuum leak post maf. Do you have a wideband. Please post an edit file or log with a list of mods would be helpful in getting you in the right direction.
Old Jun 18, 2008 | 09:44 PM
Skyfire's Avatar
all my mods are in my sig, I don't have a wide band and the motor also runs very choppy. I'll try to get a log up when I get time. Any other ideas would be great!
Old Jun 19, 2008 | 09:39 PM
Skyfire's Avatar
bump, just attached a log, any help?
Old Jun 20, 2008 | 10:01 PM
Skyfire's Avatar
someone can surely help?
Old Jun 22, 2008 | 12:39 PM
Skyfire's Avatar
ttt..
Old Jun 22, 2008 | 12:42 PM
AxisOfOil's Avatar
bump.
i've got no idea.
 Michael S. Palmer
Old Jun 22, 2008 | 12:53 PM
sreve's Avatar
ltfts could be high because the egr has created a huge leak. that can also cause misfire.
Old Jun 22, 2008 | 05:34 PM
Skyfire's Avatar
I'll look into that as well. Does it look like the o2's are both bad as well?
Old Jun 22, 2008 | 06:01 PM
sreve's Avatar
i do not know what you are scanning with but the refresh rate sucks most of the time.
if your o2s were dead you would most likely have more codes like po133,po134,po153,po154 but not nesisarily.
they are probably telling you the truth. sometimes a high voltage code will set when the pcm is dumping all the fuel it can and the trims do not come in line. o2 sensors then get replaced only to find out they were really just doing there job.
Old Jun 22, 2008 | 10:08 PM
Skyfire's Avatar
I'll try to get a better scan rate if I can when I tune, and I am really new to this so I'm not sure what all that meant but for the record I don't have air or egr anymore, and they are to my knowledge both tuned out.
