Having some alternator - wiring issues
It can be made to run through an indicator lamp that gets +12 at key-on and the other lead to the red wire on the alternator. At key-on the indicator will be on signifying no charging until the engine starts.
Alternately, you could use 75-95ish ohms between +12 ignition switched and the red wire. Stay above 65ohms with the resistor(s) or you could burn up the regulator in the alternator.
Also I tried just hooking up a switched 12 v directly to the alt red wire. Would that possibly have fried the voltage regulator in the alternator? The guy from the track said he didn't think it would so I tried it and it actually kinda worked. The battery went from a 13 V not started to a 12.2 volts when it was idling. Before I hooked up the switched 12 V at idle it was showing like 10.8V reading. I just wanted to give you a little info on what I have tried so far. ANyways
1. so you figure 75 - 90 ohm will work? In my variety pack of resistors i have a 100 ohm is the smallest one. Should I try that?
2. And do you think the voltage regulator is fried from hooking up a direct 12v from a switched power?
Any help would be appreciated.
2. Yes, most likely. I found out after I burnt the one I was speaking about up doing the same thing
The 99+up pcm handles the alt turn on signal from the RED connector, pin 15.
C220 is behind the passenger side forward kick panel (caddy corner under the glove box).
The alt turn on signal on a 98 comes from the IC, goes to C220 and then thru the firewall to the alt.
I put 12V and it fried the internals. Then I made a voltage divider (using some resistors in a Y) and sent ~5V to the new alt. and have had no issues since.
