Need help with edit
Old Aug 17, 2003 | 09:07 AM
str8evl's Avatar
Default Need help with edit
Hey guys, i have a 98 T/A with a 3400 midwest torque convertor and jet hot long tubes. I have edit but have no idea what kind of changes i need to make. Any help would be greatly appreciated. Thanks Terry
Old Aug 17, 2003 | 10:21 AM
Dave Carney's Avatar
Default Re: Need help with edit
Why did you buy Edit then? You don't have any thing that needs fixing?
Old Aug 17, 2003 | 04:02 PM
2000WhiteZ28's Avatar
I would start with the basics. Delete the 4 types of torque management, set up your shift points, shift firmness, ect.
Then set your idle where you need it.
Rev limter, gear ratios, fan turn on temps.
Autotap helps a lot.
So does http:ls1edit.slowcar.net
