PO131 code, heavy miss. help
Old Jun 22, 2008 | 11:53 AM
stepuptata's Avatar
Default PO131 code, heavy miss. help
PO131 code, ( o2 sensor circiut, Low Volts, Bank 1 Sensor 1.
Car starts and idles fine, revs fine in neutral no load. Although @ Idel you can here a little popping through the exhaust here and there. I decided too drive the car through the missing and after a few minutes, it actually got better the more I drove it. Once I stop for 5-10 minutes, It will miss heavy again for a few minutes and then start getting better. The car will also back fire a few times here and there when letting off the throttle. My car has shorty headers, STS turbo and gutted cats. TR-6 plugs and newer wires. Then the PO 131 code pops up. Is this driver front O2 sensor? , Thanks
Old Jun 8, 2013 | 11:12 AM
blackfbird98's Avatar
im surprised noone could answer this, i am having the EXACT same issue with my car hopefully someone can chime in
Old Jun 8, 2013 | 05:40 PM
Old Geezer's Avatar
B1S1 is dr ft.
Exh leaks?
Data logs?
Old Jun 10, 2013 | 10:45 PM
82cetuner's Avatar
Ususally a exhaust leak will cause a slow to respond code not a low circuit, not sure if this helps but after my tune I threw a 131 AND A 151 so both driver and pass side 02 low cirtcuit, talked to my tuner and he said it is because my idle is set a little lean to help with the surge and he forgot to adjust for it on the sensors,
