Whats up with my timing?
My engine temps never go much over 190 even after beating on it, trans temps are usually 150-160 unless I beat on it they climb to 190.
From a 0-115 run timing starts out at about 22* and by the end of first its down to 18.5* (no knock just running off low octane tables). Second gear hits and timing stays roughly the same, again no knock. Third gear hits and instantly .9* of KR brings my timing down to 15.5, it gradually decays and by 5000rpms I'm back to 17* of timing with 0 KR. Two frames go by and then I see .6* of KR, dropping my timing back down a bit then decays until I let off at 5300rpms (115 mph).
Next I do a 30-115 run. Instantly on the down shift I see 4* of KR dropping my timing to 14.5*. It decays evenly until it hits 0 KR and 19* of timing in 3rd at 5300 and stays like that until 115mph.
Next I go from 57 - 86mph. Instant 3.9* KR on the hit and gradual decay until I let out.
Finally I go from 32-90 and never see KR, timing is around 18-19*.
First thing I notice is that its running off the low octane tables and seeing no more than 19* of timing usually at WOT. Shouldn't I be able to run more than that? Second I don't understand how its so inconsistent, I mean one pass from a 30 roll it spikes to 4* KR and on a pull AFTER that when its hotter is shows 0*?? I would like to be able to bump my timing up and for the most part it seems like I should be able to but those spikes scare me.
I have not really touched anything related to spark control in the tune.
