Horrible 60 foots, is it in the tune??
Old Jun 25, 2008 | 08:54 PM
cabech984's Avatar
Default Horrible 60 foots, is it in the tune??
Ive been skimming around on here for a while as well as on the HP Tuners website and cant seem to find a good tune for a 98 Formula. Can anyone help a guy out?? Ive attached the tune file to the page, Here are the mods;
4L60 Trans(stock stall)
SLP Lid
LS6 Intake
Pacesetter LT's & ORY w/ cutout
Magnaflow Catback exhaust
MT 255/50/16 DR's
3.23 Limited Slip
The car seems to trap good(84mph 1/8th mile) but gets a horrible 2.19-2.3 60 foots with zero tirespin.
The previous tune that I ran a 12.96, 2.04 60' on 275 Nitto street tires was lost when I turned the car back to stock.
File Type: hpt
Old Jun 26, 2008 | 11:41 AM
TX RED's Avatar
what gears do you have
Old Jun 26, 2008 | 03:09 PM
cabech984's Avatar
It has a 3.23 limited slip rear axle, but the car used to spin on a 2.0 60' with street tires, and now doesnt with dr's and a 2.2+ 60' Confused???
Old Jun 26, 2008 | 03:20 PM
nick1ta's Avatar
get a stall and watch those 60's drop! stock suspension?
Old Jun 26, 2008 | 03:33 PM
cabech984's Avatar
All stock suspension. Just confused why 60's went slower w/o any tirespin????
Old Jun 26, 2008 | 04:19 PM
DrkPhx's Avatar
Too much tire for a car with a stock stall probably causing the car to bog out of the hole. Like mentioned above, a higher stall converter (even a mild 3200) would improve those 60-ft times.
Old Jun 26, 2008 | 04:32 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I think with traction you are bogging with 3.23s and a stock stall. A little spin can actually help your times in some situations
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 26, 2008 | 07:01 PM
blockheadnic's Avatar
We jut got back from the track and it defently bogged hard when it dead hooks. i think thi week a converter and cooler are on order.
Old Jun 28, 2008 | 01:45 PM
TX RED's Avatar
i had the same happing to me when i went from 315 sumitomo to 315 dr's my car would bog real bad if it had anything lower that 31psi
Old Jun 28, 2008 | 04:51 PM
edcmat-l1's Avatar
Try running it without heating the tires. As stated before, sometimes a little wheel spin helps the 60' times. Helps the engine get in its "happy zone".
