New at Tuning Question
Old Jun 26, 2008 | 10:21 AM
02BEAST's Avatar
Default New at Tuning Question
I had a WOT dynotune done already and a hptune car runs perfect except for one thing when coasting under say 10 mph or coming to a stop it still has surging and very rarely stalls until I come to a complete stop then it idles fine. I'm about to get a wideband hopefully this will correct it. Anyone have any tips.
Old Jun 26, 2008 | 01:22 PM
radkon's Avatar
Yep its in the Tune. Whoever tuned it neglected your VE table and/or RAF idle tables.
Old Jun 29, 2008 | 03:04 PM
02BEAST's Avatar
Anyone else wanna chime in.
Old Jun 30, 2008 | 06:19 PM
89LS1RS's Avatar
chime...in the tune...chime
Old Jul 1, 2008 | 07:50 AM
YellowToy/A's Avatar
Add air to the Throttle Follower table. To much air and idle will hang.
Old Jul 3, 2008 | 06:26 AM
02BEAST's Avatar
Would wideband help me get my tune perfect?
Old Jul 3, 2008 | 07:35 AM
BLK02WS6's Avatar
The throttle cracker table is the place to adjust airflow when coasting to a stop. If the idle is good when stopped and your IAC counts are good, don't mess with running airflow tables. The throttle follower is more useful for when you snap off the throttle (it would be adjusted if the rpm dips when you snap off the throttle and then recovers), its not so much used when coasting. Make small adjustments (add about .5 gm/cyl at a time) to the throttle cracker table in the lower rpm ranges and I think you will solve your problem...
