Repin PCM Connector
Old Jul 3, 2008 | 06:13 PM
BlueIroc-z's Avatar
Default Repin PCM Connector
Is it possible to buy a new 80-pin PCM connector and transfer the pins out of the old one into the new without any special tools or new pins?
I am thinking about buying a wiring harness that has a damaged PCM connector and getting a replacement connector from here. However, I need to know if I am going to be able to transfer the pins over without having to spend $40 on 80 new pins, and $30-110 on special tools...
Old Jul 3, 2008 | 08:36 PM
LS1MCSS's Avatar
Yes, you can remove the pins. After you remove the red and blue covers, the pins are easy to push out the back. You can spend 10 bucks on the special tool or just use a real small screw driver and be careful.
