TSP Torquer 3 + no tune
Old Jul 7, 2008 | 03:16 PM
b00sted's Avatar
Default TSP Torquer 3 + no tune
Will it be ok to drive around on before I get the tune? I'm gonna put the wide band in it to make sure it doesn't go excessively lean...But other than that just maybe check a plug to make sure it's not detonating? I was gonna adjust the screw in the TB to get it to idle(and recalibrate the TPS). But other than that should I do anything else? Unplug the computer overnight to let it relearn?
Old Jul 7, 2008 | 03:31 PM
YellowToy/A's Avatar
lol good luck. I dont think it will ldle well. If you go PE you will lean.
Old Jul 7, 2008 | 03:54 PM
gold98Z28's Avatar
by just messing with the TB set screw you will have to make it idle too fast to compensate for the dipping and stalling and what not that will happen, be sure to tell your tunner you messed with the set screw when you get it tuned. you should be fine to cruise around as the o2's should keep the fueling within reason while closed loop. i would keep a close eye on that wideband if you go WOT.
Old Jul 7, 2008 | 04:00 PM
b00sted's Avatar
I don't plan on going WOT or anything...Just drive around the neighborhood if needed.
As far as the set screw...I don't see how opening the blade a little is any different than the guys the drill the blade.
Old Jul 7, 2008 | 11:25 PM
iverson387's Avatar
i just put some tape where the screw is so it would idle. Drove and idled fine and this was witha ms4 cam. ill let the tuner adjust the screw and such
