160 Thermo
Old Aug 21, 2003 | 08:04 PM
SSnakekiller's Avatar
Default 160 Thermo
I just got Edit the other day and I did a successful PCM read today. I guess a good place to start with is the fans. I have a 160' T-Stat. First I did a de-program with my hypertech and set everything back to stock. Then I did the LS1 Edit PCM read. In the .LS1 file when I go to 'System' and check the stock fan settings it says:
Stage One Fan:
On - 184
Off - 175
Stage Two Fan:
On - 195
Off - 186
I thought these were the settings of the hypertech. But when the hypertech was finished it said it had set the car back to stock.
However if this is the correct stock setting then what should I set the fans to for my 160'???
Thanks
Old Aug 22, 2003 | 11:25 AM
Ed Blown Vert's Avatar
Default Re: 160 Thermo
That looks like the HyperTech settings.
