Why wont car start?
Old Aug 21, 2003 | 08:17 PM
Nickn20's Avatar
Default Why wont car start?
I have recently put in a ARE 422 motor in to my car, its a 99 SS camaro, I cant see to get the starter to engage from the key, I bypassed the relay circuit with a wire to the selenoid and it fires right up and idles fine, I tested the relay it works fine, I got power to pin 87 and continuity to pin 30 which goes to the starter, pins 85 and 86 I get nothing? no power, no ground........ any ideas?
Old Aug 21, 2003 | 10:21 PM
Jim98WS6's Avatar
Default Re: Why wont car start?
How aout the neutral safety switch if an auto or clutch switch if a stick?
Old Aug 22, 2003 | 12:09 AM
Nickn20's Avatar
car is a manual, I am pushing the clutch in, when trying to start? is that where the relay gets its ground?
Old Aug 22, 2003 | 12:20 PM
Jim98WS6's Avatar
That's one place. There may be more than that but I can't think of any more. Did you get programming from ARE too?
Old Aug 22, 2003 | 04:32 PM
Nickn20's Avatar
ed wright pcm, it didn't work his that locked crap computer, so i over wrote it with a stock 99 camaro file, and disables VATS and a few other codes. I am now getting some other weird codes as well P1635 P1639 and a few others I will post later if I find the problem
