Breathing mods and edit
Old Aug 23, 2003 | 03:33 PM
ssdungeon's Avatar
Default Breathing mods and edit
If you have z06 intake, FTRA, and a lid do you increase the RUNNING AIR FLOW table and if you do what would you increase it to? Ive seen one guy multiplied the table by 140%. What else would you edit if anything?
Could someone shed some light on this?
Thanks,
Old Aug 26, 2003 | 11:49 AM
JeremyF's Avatar
LS1TECH Sponsor
Default Re: Breathing mods and edit
NO DO NOT DO THAT! that is simply a controlled air leak, it is necessary if you have a problem with a cam, but even then 140% is HUGE. The mods will take care of themselves. Timing and fuel is where all the power is at. disable COT and TQmgnt then your off to a good start. Wanna discuss what else I can help you further. 813.253.0961
Jeremy Formato
Old Aug 26, 2003 | 12:58 PM
blue98coupe's Avatar
ok stupid question here ,what is cot??
Old Aug 26, 2003 | 01:41 PM
Catskynr's Avatar
COT - cat overtemp protection. When the cats get to hot the puter dumps in more fuel. I wouldn't recommend disabling this if you are still running cats because you could damage them.
https://ls1tech.com/threads/showflat...rue#Post658884
Old Aug 27, 2003 | 01:16 PM
ssdungeon's Avatar
Thanks,
I think I am pretty good to go then. EVERYTHING is running pretty good now and thats a first since modding. I dont know why but today even the little tapping sound is not in the engine. I will back it down I raised mine to 110 after 0... I will reset that and then I should be good to go.
