How do you log WBO2 lambda instead of AFR?
Thanks for steering me in the right direction. As I mentioned in my reply over there, it looks as if BEN_LC11 or BEN_LC12 display lambda values to the tenth decimal place. Does anyone know of another PID or some way to display a greater lambda resolution? For instance, one log I was looking at showed BEN_LC11 fluctuating between .7 and .8. I'd like to be able to see if the values were .71, .73, .77, .81, etc. I'm assuming the Innovate LogWorks program would be able to do this but it'd be so much more convenient to just look at one program. Right clicked on the dasboard then clicked on "Chart Properties". Selected the "Series" tab and in the "Format" field changed the value from %.1f to %.3f Now instead of showing lambda values like 1.0, .7, .8, etc. I now can see the values to the thousandth...i.e. 1.000, .765, .833, etc. Thanks!
The BEN factor is GM.AFR/WB.AFR to tell you how far, in percent, you are from commanded.
