Need a stock tune for a 99Z28 (LS1Edit)
Old Jul 28, 2008 | 03:20 PM
Timberwolf's Avatar
Default Need a stock tune for a 99Z28 (LS1Edit)
Any chance I can get a pcm file for a stock (or nearly stock)F-body?
I last tuned my car over 4 years ago, and it had a cam, converter, etc.
I need to realign fuel, ignition, trans tables, idle, etc with something more along my current setup.
Right now it's a stock 98 vette motor with longtubes, no cats (ORY), FTRA, and it has a stock converter.
Not looking for a custom tune, I just want to get this thing tamed a bit. I got the idle back where it needs to be, and the shift points closer, but the throttle cracker seems to be giving it a cruise control effect, and I don't remember stock values in those tables either.
Old Jul 28, 2008 | 07:42 PM
Engine_HP's Avatar
i have one for hptuners. U want it ?
Old Jul 28, 2008 | 09:58 PM
Timberwolf's Avatar
I'm not familiar with HP Tuners... is there a way to view all the tables without buying the software? I just need to see the values in the tables and copy them to ls1 edit so I can get my car closer to where it should be.
Old Jul 29, 2008 | 05:46 AM
tici's Avatar
I have almost all the F-Body + Y-Body programs from 1997 - 2002 for LS1Edit
Which one do you want?
You have a 98 vette engine and what PCM?
Mechanically the vette engine is about the same as the F-bodies, but the fuel system was different: they had a pressure regulator in the fuel rails and a return line.
At that time the F-bodies already had a semi-return system with the regulator in the tank.
Depending on the PCM and on the fuel system you'll have to take a different program.
Is it an A4 or a M6? The programs are different too.
Old Jul 29, 2008 | 08:42 AM
Timberwolf's Avatar
it's an A4 (thus the comment about now having a stock converter ), has the F-body PCM and fuel rail (but vette injectors). If you have something that'd work, I'd really appreciate it.
It's not bad now, but I can tell the throttle cracker table is probably off, and the shift points, while I have fixed them somewhat, still aren't perfect. I have no clue what changes we made to the fuel and ignition, that was so long ago.
Old Jul 29, 2008 | 11:23 AM
tici's Avatar
OK just let me know what email address
Old Jul 29, 2008 | 11:52 AM
Timberwolf's Avatar
sent you a pm
