tuned..but still stalls
but the car drives fine, no bucking or surging starts up and everything! just dies out.
im wondering if i should just drill a bigger hole in the throttle body? will that take care of it?
Never NEVER drill throttle bodies. That is a terrible solution for proper tuning.
yeah it starts up fine, drives fine and everything. its just that it dies out every once in awhile. i heard i should mess with the TB screw and that should help it out. i know it could use more tuning. but it drives fine and everything though.
Before you start tweaking, you really should pinpint exactly when/how it dies. At what temp, while you are driving, coasting, decelerating, what RPM, etc. The reason I say this is there are alot of airflow related tables in the PCM that all come into play at different times. If you start messing with stuff without knowing this.. you could make things worse.
