Fuel pressure logging
https://ls1tech.com/forums/showthrea...584&highlight=
as you can read, i use hptuners to track pressure but you could easily modify the connections to run the wire whereever. i run my wideband into the unused egr pcm connection and the fuel pressure into the old fuel sensor pcm connection. the parts came from summit. pretty simple really.
