Reseting PCM
Old Aug 26, 2003 | 08:43 PM
2000silverbullet's Avatar
Default Reseting PCM
If I reset my PCM by removing fuses from fuse box (as stated on ls1.com F.A.Q. area) will this just clear codes? Will this cause me to loose tuning from LS1 edit. (tuned by Ed W.) Any feed back would be great. Thanks...
Old Aug 26, 2003 | 09:06 PM
WS6FirebirdTA00's Avatar
Default Re: Reseting PCM
well im pretty sure it just resets it like the predator would do. dont take my word for it, if i were you just find someone with the predator and do it that way cause i know that keeps the tune.
Old Aug 26, 2003 | 09:29 PM
ss rally red's Avatar
It will clear the code but will not reset any tuning to the PCM.
Old Aug 26, 2003 | 10:16 PM
Thanks guys
Old Aug 27, 2003 | 01:23 AM
soundengineer's Avatar
the tuning is on some tables that are permanent(thats why you have to flash it)....all the reset does is make it have to decide on which tables to use...and if you have tuned...then all the tables read for your tuning....get it...got it...good....
