TunerCat Tuning: Info and Help
Old Jul 30, 2008 | 09:51 AM
RickyMartinZ28's Avatar
Exclamation TunerCat Tuning: Info and Help
Where do you find info and help for TunerCat's software? Some of the tables use values in a sense that I'm not familiar with and I'm not sure how to modify them correctly.
Also, trying to adjust my shift firmness and not really sure what table I need to modify and what to change.
Just wondering where a good place to get info is...
-Rick
Old Jul 30, 2008 | 09:57 AM
hellbents10's Avatar
LS1Tech Sponsor
monodax.com and go to the forums.
Old Jul 30, 2008 | 03:36 PM
All I'm really looking for is a decent A4 tune. I want to change my firmness but no one really seems to have any good info or a decent tune...
I'm not sure what tables to modify...
-Rick
Old Aug 1, 2008 | 03:31 PM
lt170chevelle's Avatar
On mine i upped the line pressure tables by 5 and also in the constants you have a max press value that will need added to. and depending on if you want you can change the shift points a little higher for better power or lower for better economy. also you can change all your shift time values to 500. thats the best i can do
Old Aug 4, 2008 | 09:35 AM
Does anyone have any good transmission tunes etc? Monodax doesn't have much either...
-Rick
Old Aug 5, 2008 | 02:44 AM
dmoss69's Avatar
Default call
Holla at me sometime tommorow, I'll try and help. If I don't answer, leave a message, I'll call you back.
(803)682-5099
David
