FI help w/T76 2Bar
Old Aug 3, 2008 | 03:32 PM
Reject's Avatar
Default FI help w/T76 2Bar
Am trying to get the car to idle at more closer to 14.7, as it's idling around 11.5.
I copied over my stock VE table to the new 2Bar config and changed my injector size for the 60 pounders (if someone can double check on that to make sure i did it right please)
Am going to try and tune it below the boosted area's and take it to the dyno to let them finish the top end
oh yeah, this is going to be in OLSD
here's the file thanks for looking!
http://reject.sleepingz.com/HPT/CARR...TARTER%201.hpt
Old Aug 3, 2008 | 04:56 PM
foff667's Avatar
LS1TECH Sponsor
Your maf codes are setup so that you will never go into SD mode. I would say start there & then move on to tuning.
Old Aug 3, 2008 | 09:47 PM
Reject's Avatar
thanks for the help so far, i will upload the right tune tomorrow after work, other than that dose the fuel scaling look right?
