2006 LS2 wiring ?'s
1. Can the computer be programmed to delete 2 of the oxygen sensors because there are 4 in the harness and I would only like to use 2 of them.
2. Also can the VATS be disabled so the car will run without stalling seconds later?
3. The current motor has a vent for the fuel system does the computer read that and do I need to have that hooked back up or can I do away with it and vent it at the tank?
4. And the last question is who does this?
Thanks guys.
any tuner that has experience should be able to tune some of the stuff to your specs.
