log screen shots.......... HELP
Old Aug 28, 2003 | 08:41 PM
Assassin's Avatar
Default log screen shots.......... HELP
I said in another post that the check engine light came on about 10 min. after I filled up with gas, and I wuz thinking it wuz because of bad gas, look at these shots and lemme know what you think...., and also, wtf is up with the oil pres.?, on my dash guage it reads normal 40 to 50 psi. but on the log it reads -15psi. should I be concerned? I'm still just learning how to use this thing, this is the first time I've hooked it up and used it, I got it yesterday, but if I'm not mistaken that bs1 stuff is fuel bank 1 right? could a crusty fuel filter cause this or could the bad gas get past that? check it...........
Old Aug 28, 2003 | 11:57 PM
Assassin's Avatar
Default Re: log screen shots.......... HELP
does anybody have a clue whats up!
Old Aug 29, 2003 | 01:05 AM
Assassin's Avatar
ok, so the H02 B1S1 is the driver side or pass. side o2 censor? in the front right? now... if I did get the "bad gas" like I think the 02 censor would show this malfunction because its burning a different type of fuel right?, I'm going to drain the fuel, check the fuel filter and put some good gas in it, but what about the damn -15psi oil press., the dash guage reads 50psi!, could this be a loose wire of some sort?
Old Aug 29, 2003 | 01:42 AM
miner_49's Avatar
I don't know if it does it with F-bodies as I have yet to encounter it with my Trans Am, but my '99 Pontiac Grand Am will get a check engine light soon after a fill up when I don't put the gas cap back on properly.
Old Aug 29, 2003 | 02:03 AM
HumpinSS's Avatar
Bank 1 sensor 1 is the drivers side. The oil pressure doesnt work with loggin tools. Forget about it, it doesnt work
Old Aug 29, 2003 | 03:43 AM
Assassin's Avatar
its NOT the gas cap, a few people have reccomended that allready, thanks though, I'm thiknin iether bad 02 or dirty fuel, I just came up for a drink, I'm draining the fuel right now, and going to start fresh,
thanks HumpinSS about the oil pressure info, I wuz trippin
Old Aug 29, 2003 | 09:47 AM
LEATHL_WS6's Avatar
What code are you getting. GO to odbII then go to dtc codes. That will tell you why the SE light is on.
By Brett Foote | 2026-06-04 05:00:17
