42's n/a anyone have a file? im installing the 42# injectors in the 370 on monday, and i was wondering if anyone had a similar file i could compare with? basically need somehing to ballpark the for the injector offset, and i *think* i can pretty much do the rest to match. |
Re: 42's n/a anyone have a file? What are your mods? in further detail send me a pm or email and I can help. ie what maf, LS6 intak? ported TB and if you send me a .ls1 that would be better. |
Re: 42's n/a anyone have a file? I have 42s in my car, but I only messed with the injector flow rate, not the offset. I didn't think it was necessary? |
Re: 42's n/a anyone have a file? TTT anyone have any info on offset tables? |
Re: 42's n/a anyone have a file? well thanks guys for the feed back. i just went to messin with it last night. installed the 42's (over the stockers.. :o ) and changed the injector flow rate (not the offset, my typing mistake.) by *165 at first, and atap showed it to be rich under normal driving conditions, and lean under wot, so, i went with a 175 setting, put all the timing back in and man, what a diffrence. i can finally feel all my motor up top ;D still need to tune it for WOT on the dyno (i still feel i have roughly 20-30 HP more to find at WOT), and if it's not what i want, im going solid roller for sure. :D |
Re: 42's n/a anyone have a file? ...i just went to messin with it last night. installed the 42's (over the stockers.. :o ) and changed the injector flow rate (not the offset, my typing mistake.) by *165 at first, and atap showed it to be rich under normal driving conditions, and lean under wot, so, i went with a 175 setting, put all the timing back in and man, what a diffrence... |
Re: 42's n/a anyone have a file? Wouldnt increasing the IFR lean it out even more at WOT? |
| All times are GMT -5. The time now is 07:17 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
