42's n/a anyone have a file?
Old Aug 29, 2003 | 12:43 PM
Vents's Avatar
Default 42's n/a anyone have a file?
im installing the 42# injectors in the 370 on monday, and i was wondering if anyone had a similar file i could compare with? basically need somehing to ballpark the for the injector offset, and i *think* i can pretty much do the rest to match.
Old Aug 30, 2003 | 12:13 PM
JeremyF's Avatar
LS1TECH Sponsor
Default Re: 42's n/a anyone have a file?
What are your mods? in further detail send me a pm or email and I can help.
ie what maf, LS6 intak? ported TB and if you send me a .ls1 that would be better.
Old Aug 31, 2003 | 09:39 PM
Jorday's Avatar
I have 42s in my car, but I only messed with the injector flow rate, not the offset. I didn't think it was necessary?
Old Sep 2, 2003 | 03:03 AM
Nickn20's Avatar
TTT anyone have any info on offset tables?
Old Sep 2, 2003 | 09:50 AM
Vents's Avatar
well thanks guys for the feed back. i just went to messin with it last night. installed the 42's (over the stockers.. :o ) and changed the injector flow rate (not the offset, my typing mistake.) by *165 at first, and atap showed it to be rich under normal driving conditions, and lean under wot, so, i went with a 175 setting, put all the timing back in and man, what a diffrence. i can finally feel all my motor up top ;D
still need to tune it for WOT on the dyno (i still feel i have roughly 20-30 HP more to find at WOT), and if it's not what i want, im going solid roller for sure.
Old Sep 19, 2003 | 06:13 PM
Mike00FRC's Avatar
...i just went to messin with it last night. installed the 42's (over the stockers.. :o ) and changed the injector flow rate (not the offset, my typing mistake.) by *165 at first, and atap showed it to be rich under normal driving conditions, and lean under wot, so, i went with a 175 setting, put all the timing back in and man, what a diffrence...
Wouldnt increasing the IFR lean it out even more at WOT?
Old Sep 20, 2003 | 09:42 AM
Billiumss's Avatar
DITTO?
