A4 shift points with edit
Old Aug 29, 2003 | 09:47 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Default A4 shift points with edit
I have all the data from atap as far as mph and rpms what should i change in edit for my shift points.thanks
Old Aug 30, 2003 | 11:51 AM
JeremyF's Avatar
LS1TECH Sponsor
Default Re: A4 shift points with edit
If you send me a .ls1 file I can take a look at it and do you have a dyno sheet? Where do you make peak power? Have you recalled the speedo for the gears? Where are you shifting @ now?
IU would think you should be making peak @ 6400. so I would set the shift pt for 1-2 65-6600 or so the 2-3 6450-6550 and the 3-4 6400-6450. Ill let you know MPH if you can get me some more info.
Jeremy Formato
