delphi and slp 85 maf calibrations
Old Aug 12, 2008 | 07:11 PM
slow trap's Avatar
Default delphi and slp 85 maf calibrations
well i'm a newb tuner so bare with me. trying to get my slp 85 maf right because it is pig rich and have a buddy with the same issues with an 85 mm delphi. using efi live. his is a 98 pcm amd mine is a 2002 if that matters. anyone have a maf recalibration table to help us get close or does a person have to log data ? i'm an idiot so if it is just a different table that gets close that would be great.
thanks,mark
Old Aug 13, 2008 | 03:13 AM
Brice's Avatar
i want one too for 85 mm delphi !
I've taken the 2001 MAF C5 table, now I've got errors code ! (lean)
I've got no wideband to calibrate it. I'm looking for a 85 Delphi MAF table which works for f bodies !
Old Aug 13, 2008 | 05:56 AM
BLK02WS6's Avatar
Fact is, if you are messing with MAFs and/or MAF tables without a wideband to verify what your AFR is, you are playing with fire... The only way to get any of the fueling tables correct is to use a wideband - especially for WOT where you can do the real damage! This is especially true of the aftermarket 85mm MAFs - I've seen them all over the place as far as fueling goes...
Old Aug 13, 2008 | 07:37 AM
slow trap's Avatar
i have a wideband. i was just looking for a table to get me close and save alot of trouble.
Old Aug 13, 2008 | 01:39 PM
Aaron91RS's Avatar
MAF Type freq Hz 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625 2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000 4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375 5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750 6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125 8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500 9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875 11000 11125 11250 11375 11500 11625 11750 11875 12000
Truck ZL1 02 flow gm/s 0.2 0.27 0.34 0.41 0.49 0.58 0.66 0.73 0.81 0.89 0.97 1.05 1.13 1.21 1.29 1.59 1.88 2.2 2.58 2.99 3.45 3.95 4.5 5.1 5.76 6.46 7.23 8.06 8.95 9.9 10.91 11.98 13.14 14.39 15.74 17.19 18.74 20.39 22.14 23.99 25.95 27.99 30.14 32.38 34.71 37.16 39.73 42.5 45.41 48.47 51.67 55.02 58.48 62.1 65.86 69.77 73.82 78.06 82.48 87.07 91.82 96.74 101.82 107.08 112.48 118.07 123.83 129.76 135.87 142.17 148.61 155.26 162.11 169.17 176.44 183.94 191.72 199.8 208.06 216.62 225.44 234.52 243.89 253.45 263.21 273.23 283.55 294.15 305.06 316.32 327.93 339.92 352.32 365.16 378.47 392.3 406.7 421.7 437.34 453.69
Old Aug 13, 2008 | 02:23 PM
slow trap's Avatar
is that for the 85 mm delphi ?
