Nutty O2 oscillation. WTF?
Old Aug 13, 2008 | 08:28 PM
BigBirdTA's Avatar
Default Nutty O2 oscillation. WTF?
I can't figure this one out. The car runs fine during the South Florida heat during daytime hours. But when I run the car after it cools off in the evening hours, it farts, pops and backfires. Checked for the obvious like wires, plugs, even swapped O2's TWICE with brand new ones. Tried brand new AC/Delcos twice and now third time around, tried Bosch 13111's to see if it made any difference.
So, finally found my HP Tuners cable and slapped the scanner on it and took these two logs today. 1st one is the one taken at 9:00pm after things have cooled off - farting, popping and backfires. Car sometimes feels like it's dropped a cyl or is firing less than 8 holes.
Notice how the driver side O2 oscillates but stays in the upper range of the mv. Pegging the high side of each oscillation and only coming down to about 350mv. No amount of driving will make if finally correct and start oscillating through the whole range.
The second is for reference, it was taken in 95* F around noon, with about 1,000,000% humidity here in the swamp. Car ran fine, no issues.
It's been doing this for a few weeks. Under the hood is a TSP 408, MS3 with a FAST 90/90. Don't pay too much attention to the LTFT's as I started messing with the tune to see if I could tune it out, so they may be off cuz the car hasn't completely learned the trims.
What the hell is up with that Driver side O2?
Attached Thumbnails Nutty O2 oscillation. WTF?-9pm.jpg   Nutty O2 oscillation. WTF?-1130am.jpg
Old Aug 14, 2008 | 09:56 AM
wait4me's Avatar
It could just be a leak on your header tubing or in the intake or fuel injector rings.
Have you tried unplugging your MAF to see if the problem goes away?
Old Aug 15, 2008 | 10:47 PM
BigBirdTA's Avatar
Took another log. This time later in the evening 11:15pm after the car had sat for over 6 hours. Looking at the log, it clearly gets wierder still.
Wait4me, thanks for the suggestions. I had been thinking along the same lines, with a header leak being my primary suspicion. But if suspecting it's a leak (header or intake), it will either leak or it doesn't. How is it that it runs fine during the day, but goes downhill as soon as it gets dark?
Will be pulling header and inspecting O2 harness next week.
Anyone seen this before?
