would the real tuners please stand UP ?
Ryan
-Geoff
Engine>Airflow>Dynamic Airflow
high RPM disable to 8K
Deep Decel MAP 0.00 kPa
Engine>Airflow>Steady State
hi/lo rpm thresh 8K
hi/lo MAP thresh 105kPa
hi MAP Delta 0kPa
lo TPS Delta 100%
hi TPS Delta 100%
idle MAP Integ Time 255
idle map Integ Threshhold 0.00
Idle VSS Max 0.0
Idle TPS Max 0.0%
Idle MAP Time Enable 255
Idle MAP Threshold Enable 0.00
hi/lo rpm thresh 8K
hi MAP Delta 0kPa
lo TPS Delta 100%
hi TPS Delta 100%
Idle VSS Max 0.0
Idle TPS Max 0.0%
I'd be glad to take a peek at it for you...
This will cause IMMEDIATE system check readiness.
P0131-P0167
P0400-P0430
P1133-P1156
P1404-P1416
P1441-P1443
Set to "NOT REPORTED" Concerning the MIL (DTC's) light codes...just turn them off "DISABLED"
Maybe they are just sporting a different name?
