car won't lean out at WOT?
Old Aug 31, 2003 | 11:12 PM
strokedls1's Avatar
Default car won't lean out at WOT?
It's a 98 m6 with heads cam, and stock 10 bolt rear. The ltrim's are perfect at cruise speeds, but the car goes 11.9 to 1 at WOT. PE vs rpm did nothing to bring it up. I was using a wideband O2 so I know the a/f is accurate. Should I play with the maf table since it's an SLP maf? Any help would be much appreciated.
Old Aug 31, 2003 | 11:17 PM
WS6 GreeN's Avatar
Default Re: car won't lean out at WOT?
adjust the maf table a little at a time and see if it makes a difference.
Old Aug 31, 2003 | 11:33 PM
strokedls1's Avatar
Yah, I was thinking about doing that. I didn't know if that would have negative effects in some other area. I will try it though.
Old Sep 3, 2003 | 02:47 PM
gojo's Avatar
Before you try changes in settings, set COT to false and see if that helps.
Old Sep 3, 2003 | 04:12 PM
MyLS1Hauls's Avatar
Old Sep 3, 2003 | 07:18 PM
SS SLP2's Avatar
Just a note:: if still runing cat,s and you turn off COTS you may burn your cats( think warrenty for 7 years and 80 k miles )
