bad tune or bad valvetrain
Old Aug 30, 2008 | 01:17 PM
shannon french's Avatar
Default bad tune or bad valvetrain
so i used my hp tuners to scan my car as i did some thrashin to tryand figure out why i have a hickup between 5000-6000 rpm. car pulls hard any other rpm but up around in there not so much an dif u listen closely it sounds liek its skippin beats. i have done plugs, wires, fuel filter, pcv as far as tune-up stuff goes. here are the scanner logs maybe some oen wil see sometin that i dont. just trying to figure out if its just the tune or did somethin in my vavletrain die. thanx
File Type: hpl
File Type: hpl
Old Aug 30, 2008 | 02:04 PM
no KR was found and as fo rthe a/f ratio i dont have a wide band. i did adyno back in spring and it wasn't too far off so i adjusted it then. i stil ha dthe same hick-up that day as well. and also i just swapped out my o2 sensors as well.yeah any one will ned the hp tuners inorder to look at it
Old Aug 30, 2008 | 07:12 PM
anyone else ??
Old Aug 31, 2008 | 07:56 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Well, without even looking at your logs, what's done to the car? Heads, cam, valve springs, etc.
If you have a valvetrain instability, it usually shows up in this area and you get valve float/flutter which would kill your power.
Old Aug 31, 2008 | 08:05 AM
UNDER PRESSURE MOD
The first thing I notice is that at higher rpms your throttle position is actually decreasing. You're going from 100% down to 94-96% throttle. Not sure how much of a difference that will make, but talk to Joe Gibbs racing about how much less power a partially closed throttle body makes.
Old Aug 31, 2008 | 09:01 AM
Cam72aro's Avatar
lol, at your Joe Gibbs comment. The change in throttle position could be part of the problem.
